Wah and Volume assignements with internal and external expression pedals
z3albw1rr
I'm fairly sure it's capable of this, but just to be 100% sure:
Could I assign the Wah to an external Expression Pedal (EXP2) and use it as a switchless wah?
Then keep the internal pedal as EXP1 to run to Volume and put the Volume pedal at the end of the line - last thing before the outputs?
Unfortunately not. When an external expression pedal is connected, the on board expression defaults to EXP1 which is wah and you can't then assign a wah to EXP2. This makes an external expression pedal of limited value as all it does is avoid having to stomp change between wah and volume or whatever you've programmed external EXP2 to control.
A-ha - Thanks. The Pod Go was looking like a no-go again, and this really cinches it.
