Pod Go into 2 amps, stereo
ricardofiel
No, the Amp Out is a mono signal. If you want to connect to two amps in stereo, you’d need to use the left and right outs.
I guess you could possibly use the FX Send as an alternative. You’d have to set the Mix parameter in the FX Loop block to something less than 100 (50 would give you equal signals from the Send and going through the POD).
Are you wanting to connect to the PA at the same time?
No PA, just straight into 2 amps in stereo. Thanks
