Rocco_Crocco Posted May 6, 2022 Share Posted May 6, 2022 The octave knob just seems to add more fuzz to the guitar sound. Isn't this supposed to add an octave down to the guitar signal? Also, the filter knob does nothing. I think these are bugs. Quote Link to comment Share on other sites More sharing options...
Rocco_Crocco Posted May 8, 2022 Author Share Posted May 8, 2022 Can anyone else with the Doom plugin verify this? Quote Link to comment Share on other sites More sharing options...
Wah-bisca Posted May 9, 2022 Share Posted May 9, 2022 Hello! Just wanted to verify your DAW and system for QA. I have looked at the Doom plugin and cannot reproduce what you have described. Testing the parameters I noticed with a sine wave that a higher octave is present when adjusting the octave parameter- similar to that of a proctavia, and with pink/white noise the filter seems to to be functioning as a low pass. These parameters may seem more subtle than expected but are functioning on Window 10 [AAX]Pro Tools/[VST]Cubase. Hope this helps! George 1 Quote Link to comment Share on other sites More sharing options...
Rocco_Crocco Posted May 9, 2022 Author Share Posted May 9, 2022 On 5/9/2022 at 12:30 PM, GeorgeWabisca1 said: Hello! Just wanted to verify your DAW and system for QA. I have looked at the Doom plugin and cannot reproduce what you have described. Testing the parameters I noticed with a sine wave that a higher octave is present when adjusting the octave parameter- similar to that of a proctavia, and with pink/white noise the filter seems to to be functioning as a low pass. These parameters may seem more subtle than expected but are functioning on Window 10 [AAX]Pro Tools/[VST]Cubase. Hope this helps! George I thought I read that the octave control was producing an octave below rather than an octave above. Looks like its working as it should. Thanks for clearing this up. Quote Link to comment Share on other sites More sharing options...
