garrybanjo Posted July 6, 2022 Share Posted July 6, 2022 Hi there, apologies if this has been asked/answered before - I have searched and found a couple of related answers but none exactly match my situation. I would like to use two instruments through my HX Stomp on stage but only play one at a time. There would be completely separate patches fpr each instrument. I guess I could use an A/B switch at the input but I believe there must be a way of using the two Stomp inputs. If there was a way of selecting the input in each patch this would be ideal but I don't see it anywhere. Using the Split A/B send the input down separate paths - not what I want as the two instruments will never be played at the same time. I feel the solution should be obvious, what am I missing? N.b. one of the instruments has no volume control so the input will always be hot from that instrument - I need to be able to isolate inputs by patch. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted July 6, 2022 Share Posted July 6, 2022 If you want to change presets while keeping both instruments plugged in, you can move all blocks to path B, then use the Y Split at the beginning to assign the respective channel to it. The other channel goes to the blank path A which you then mute in the Mixer block at the end. Quote Link to comment Share on other sites More sharing options...
lou-kash Posted July 6, 2022 Share Posted July 6, 2022 Alternatively, you can also plug instrument 1 into Main In, and instrument 2 into Return In. Then you simply switch the Input block on each preset. Quote Link to comment Share on other sites More sharing options...
garrybanjo Posted July 6, 2022 Author Share Posted July 6, 2022 Thanks lou-kash, I'm going to go down the Return In route. Quote Link to comment Share on other sites More sharing options...
