jcshirke Posted July 14, 2022 Share Posted July 14, 2022 (edited) My DL4 MKII is in a loop in my Gigrig G2. The G2 is a little odd, since it automatically sends PC commands every time you step on a footswitch. Footswitch 1 sends PC 1. Footswitch 2 sends PC 2--and so on. There is a "hidden preset" that sends PC 0. Everything works fine when I save my presets and call them up with MIDI, as long as I am saving to DL4's bank 1 (presets 1, 2, and 3, Bank 1's A, B, and C buttons). However, when I try to save to preset slots 4, 5, and 6, I have problems. I know the DL4 is receiving MIDI from my G2 because (for example), when I press footswitch 5 on my G2, it calls up preset 6 in the DL4. But, if I try to modify and then save that preset to slot 6, I have problems. The DL4 is saving my preset, but it's saving it to preset slot 3 ("C" in bank 1) and not slot 6 ("C" in bank 2). Any ideas how to fix this? Is this a bug? And, to make things even weirder, if I try to save a preset via MIDI that is beyond the first two banks of presets in the DL4 (in other words, preset 7 or above), it works. There is just something odd about trying to save a preset in slots 4, 5, and 6 via MIDI. Those presets will save in slots 1, 2, and 3 instead--in other words, to bank 1, not bank 2. Update: I decided to repurpose my tap tempo button to access presets D, E, and F. It's not working either. My tap tempo button changed to yellow, but toggling it does not change the color from dim to bright yellow, and it's not calling up the other bank of presets. I was going to try to save my presets to the D, E, and F locations first, and then see if calling them up by MIDI after switching my tap tempo back to the default tap setting worked. Has anyone else had issues making the tap tempo button toggle between presets A, B, C and D, E, and F? Edited July 14, 2022 by jcshirke Quote Link to comment Share on other sites More sharing options...
Wayman7 Posted January 16, 2023 Share Posted January 16, 2023 I got the same problem - found this question and hoped for answers. Nothing? I'm close to sending my unit back. Thanx for any help, Marc Quote Link to comment Share on other sites More sharing options...
Wayman7 Posted January 16, 2023 Share Posted January 16, 2023 Seems like you need a midi controller that you got to programm for every individual parameter? That's how it sounds in the manual. That would be a hell lot of work apart from the fact I just use a midicontroller that sends out 128 programm change orders. What is the deal in pressing the button longer to save the programm on the choosen preset? But that doesnt work. Quote Link to comment Share on other sites More sharing options...
kspradling Posted January 31, 2023 Share Posted January 31, 2023 I have the same problems. Hopefully a firmware update is in order to resolve it. Until then I'm using presets 125-127 to replace presets 4-6. I'm using a morningstar MC8 so it's no problem....just messes with my OCD a bit. Quote Link to comment Share on other sites More sharing options...
duc1000 Posted January 25, 2025 Share Posted January 25, 2025 Did anyone solve that problem? thanks Quote Link to comment Share on other sites More sharing options...
