craiganderton Posted August 17, 2022 Share Posted August 17, 2022 I thought some of you might find this helpful...boosting EQ around 3 kHz will make an overdriven amp more responsive to leads. The screenshot below shows four identical riffs. The first is played starting on low E, the second an octave above, another octave above that (i.e., starting on the open first string), and finally, the octave starting on the first string, twelfth fret. The lower image shows the same file, but processed with a major boost around 3 kHz. The level of the lowest frequency’s riff is essentially unaffected, the second one is boosted somewhat, but the two higher riffs have considerably more level. This makes for a more even, sustained sound with solos played on the higher frets. If you want more info, I wrote this up originally about Guitar Rig for a Native Instruments blog post. 2 2 1 Quote Link to comment Share on other sites More sharing options...
boynigel Posted August 18, 2022 Share Posted August 18, 2022 how many db is this "major" boost? thanks Quote Link to comment Share on other sites More sharing options...
craiganderton Posted August 19, 2022 Author Share Posted August 19, 2022 The linked post shows the settings - it's cranked up to +20, but the ideal value for your setup depends on the input level going into the EQ, and the input level/drive setting on your amp. I don't hit inputs all that hard, I need the extra gain. Unfortunately, there's no "one-size-fits all" setting...which come to think of it, pretty much applies to anything involving amp sims :) Quote Link to comment Share on other sites More sharing options...
