tdguitar Posted August 24, 2022 Share Posted August 24, 2022 So far the Command Center has be a great addition to the HX Stomp line. It would be great to be able to assign switch functionality to Double Tap and Long Tap (Hold). This already works on the 1 switch looper, so I'm guessing it should be able to program this for anything else in the pedal. (?) Would be great for the 3.2 Firmware Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 24, 2022 Share Posted August 24, 2022 On 8/24/2022 at 10:03 AM, tdguitar said: So far the Command Center has be a great addition to the HX Stomp line. It would be great to be able to assign switch functionality to Double Tap and Long Tap (Hold). This already works on the 1 switch looper, so I'm guessing it should be able to program this for anything else in the pedal. (?) Would be great for the 3.2 Firmware Hi, We all live in hope of Line 6 grabbing all the possible firmware modifications out of thin air, although they cannot implement things they are not aware of. It’s a little late for 3.2 as it’s almost about to go into Beta, don’t hold your breath. Line 6 staff do not monitor these forums, and very rarely do they visit, so you need to sign up to IdeaScale which you can find here: https://line6.ideascale.com/c/home Once you've signed up and are in there, find the Helix/HX section from the menu at the top of the page, then you can post your ideas among the other 5,500 plus requests, but it is the only place where it might get picked up. Please Note: before submitting your ideas, search through all the other requests to ensure you are not duplicating ones that may already be in there. If you don't check, then you will only succeed in watering down the votes the item may already have accumulated. Once you have added to the IdeaScale site, you can post here, to the "sticky" thread at the top of the main forum page to let other users know and to encourage them to upvote your idea. Link: Hope this helps/makes sense. 2 Quote Link to comment Share on other sites More sharing options...
tdguitar Posted October 6, 2022 Author Share Posted October 6, 2022 Thanks! I will! 1 Quote Link to comment Share on other sites More sharing options...
