diegovation Posted January 27, 2023 Share Posted January 27, 2023 hi, i use the line 6 pod go, and i have a guitar taylor t5z, the guitar has not the vibrato lever, so i need to create a patch and working on the pedal i can to have the same effect, is it possible? someone can help me? thanks very much Quote Link to comment Share on other sites More sharing options...
theElevators Posted February 20, 2023 Share Posted February 20, 2023 On 1/27/2023 at 12:41 PM, diegovation said: hi, i use the line 6 pod go, and i have a guitar taylor t5z, the guitar has not the vibrato lever, so i need to create a patch and working on the pedal i can to have the same effect, is it possible? someone can help me? thanks very much You can simply add a vibrato "bubble vibrato" works pretty nicely in the beginning of your chain: guitar->vibrato->amp..... Max out the depth and the mix. Then set the speed to 4.1... or to taste. It's not a replacement for your whammy bar, but a good substitution. If you want to go crazy, you can set the depth to be controlled by the expression pedal... also the speed. But this will get you close enough... Quote Link to comment Share on other sites More sharing options...
