maxm17 Posted February 16, 2023 Share Posted February 16, 2023 Hey all. Anyone else having this issue? Don't feel like this was happening prior to 3.50. Using HXFX in mono (left (mono) main out to FX loop). Create a separate signal path in HXFX. No matter where the split signal path returns to the "main" signal path, it clearly sounds out of phase. Unusable. Doesn't matter if there is an effects block in the split signal path or not. I looked in the bug database and did not see anything. Any idears? Thanks! Quote Link to comment Share on other sites More sharing options...
datacommando Posted February 17, 2023 Share Posted February 17, 2023 On 2/16/2023 at 11:40 PM, maxm17 said: No matter where the split signal path returns to the "main" signal path, it clearly sounds out of phase. Hi, Just a guess, but select the point where the Path B signal returns to the Path A. It’s actually a mixer block and you should check that (page 2) the option to invert the polarity of Path B is set to Normal. See the HX Effects 3.0 Owner’s Manual - Rev C - English - Page 38 - Mixer Settings > Page 2 > Knob 2 > B Polar https://line6.com/data/6/0a020a411710a6112a67116f0b/application/pdf/HX Effects 3.0 Owner's Manual - Rev C - English .pdf Hope this helps/makes sense. Quote Link to comment Share on other sites More sharing options...
maxm17 Posted February 17, 2023 Author Share Posted February 17, 2023 On 2/16/2023 at 4:08 PM, datacommando said: Hi, Just a guess, but select the point where the Path B signal returns to the Path A. It’s actually a mixer block and you should check that (page 2) the option to invert the polarity of Path B is set to Normal. See the HX Effects 3.0 Owner’s Manual - Rev C - English - Page 38 - Mixer Settings > Page 2 > Knob 2 > B Polar https://line6.com/data/6/0a020a411710a6112a67116f0b/application/pdf/HX Effects 3.0 Owner's Manual - Rev C - English .pdf Hope this helps/makes sense. Great advice. Will give a try! :) Thanks much. 1 Quote Link to comment Share on other sites More sharing options...
