ts020572 Posted March 13, 2023 Share Posted March 13, 2023 I need some help to get the best - and maybe least complicated - setup for using my HX Effects with two tube amps, only for FX (delay, reverb, chorus) in both FX loops. The amps will not be running at the same time. I would like to use the HX Effects as MIDI controller for both amps, one at MIDI Ch 1 and the other at MIDI Ch 2. I started with the idea using Path A and B at the HX FX, panned hard left and hard right, but I guess I could just use one path, even if I use Input 1 and 2, and Output 1 and 2? Connections are: Amp 1 FX send to HF FX Input 1, HX FX Output 1 to Amp 1 FX return Amp 2 FX send to HX FX Input 2, HX FX Output 2 to Amp 2 FX return Thanks in advance. Quote Link to comment Share on other sites More sharing options...
