Isp g string
paulevans253
Hi
I've 2 issues really
I've got my hx effects set up with 4cm but when I use my digetch drop going to front of Amp I still get signal none de tuned coming trough
Amp is jvm410h fx loop full wet
I also am checking the connection configuration to my isp g string as this maybe the culprit
If you are wired like this:
Guitar>DD>Amp Input>?
Then you are NOT wired in 4cm.
4cm:
Guitar>DD>HXFX Input>HXFX Send1>Amp Input>Amp Send>HXFX Return1>HXFX Out>Amp Return
  • Thanks 1
