DarfnageL Posted March 20, 2023 Share Posted March 20, 2023 I'm currently running into an issue where if I have my HX Stomp connected to my MacBook Pro with Logic Pro open and a track enabled with the HX Stomp set as the input, any audio into the HX Stomp then triggers the "Analog Bypass! Press Any Switch." prompt and no audio is passed. If audio is continuing, pressing a switch will briefly go back to the main page and audio will pass before the analog bypass is triggered again. Disconnecting from USB or quitting Logic Pro will resolve the issue, but it means I cannot record using the HX Stomp at this time. I have currently gone through a number of troubleshooting steps. I have: tested with multiple USB cables, issue persists Tested with the MacBook Pro on a power adapter or battery, issue occurs with both Reset to factory settings and restored my presets, issue persists Reset to factory settings and did NOT restore my presets, issue persists Updated HX Edit, the HX Stomp, and Logic Pro, issue persists Currently I am running MacOS Ventura 13.0, Logic Pro 10.7.7, and the latest firmware for HX Edit and the HX Stomp. Any help or insight would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
kduck Posted March 20, 2023 Share Posted March 20, 2023 Very strange. Maybe check to make sure that Logic isn't sending a MIDI CC #70 message. 1 Quote Link to comment Share on other sites More sharing options...
DarfnageL Posted March 20, 2023 Author Share Posted March 20, 2023 On 3/20/2023 at 9:31 AM, kduck said: Very strange. Maybe check to make sure that Logic isn't sending a MIDI CC #70 message. You are awesome, I had already gone through my midi settings in logic but I checked again and was looking for anything left that might still be sending messages. I had an old sample pad controller that was sending messages over #70. Removed it, and I'm back in business. Saved my butt there! Thank you! 1 Quote Link to comment Share on other sites More sharing options...
