Stereo mic in PodFarm with ux2
I'm not sure I understand. Each mic is a mono device; you can't generate a stereo signal on input. It seems correct to me that at the time of input/recording each mic is assigned its own channel, L or R. At the OUTPUT or post-recording stage you should be able to blend the two inputs into a stereo signal.
On 4/28/2023 at 10:23 AM, dallascowboyfan said:
If set on this setting, wouldn't it automatically combine both mic inputs to make it stereo? I've had this unit for almost 20 years now, and just started getting curious about it. So, yes I'm still a newby.
Yes, it should. How exactly do you know that it’s not?
I spent all night last night going through the Manuel from cover to cover, and I can't figure this out, which is very unusual for me. I'm usually pretty up on this stuff, but it don't help that the Manuel keeps jumping from one set top to another. Makes it kind of hard to keep up with which one your looking at.
Just to be sure... are you actually using two mics, one plugged into each input? The symptoms you describe suggest you may be using only one mic and expecting a stereo input. That's impossible. A stereo input requires two separate physical input sources which it calls L and R.
OK, that's my answer! It's not possible to get the stereo affects with just one condensor mic! As I said I'm a Newby, and we bought this just to do family Karaoke with the kids, so I just never looked into it before. Now I got a son, who is taking this a little more serious, so I started checking into it a little further. I'll just buy him another matching condenser mic, and fix it that way. Thanks for the help bro!
Well, now I understand what you are trying to do, and you can do it with Pod Farm. I didn't say you can't get stereo EFFECTS with just one mic. I said you can't get a stereo input signal. But even with a mono input (one mic) you can get stereo FX in your output signal when using a device/instrument like POD Farm. That has stereo FX that work by taking a mono input, splitting it internally into duplicate L and R channels, processing each channel separately, and producing a stereo output. So by using one mic and using Pod Farm stereo FX blocks you can generate a stereo output. It's just that you won't be able to distinguish between different external inputs.
For instance, you can have two singers sharing the one mic and set the FX up so that both voices simultaneously ping-pong back and forth between the two speakers. But you can't have one voice in one speaker and the other voice in the other speaker, or have the two voices panned differently in the stereo field. For that you would need two mics.
