A Cheat Sheet, FW 3.60 – Amps Cab’s and Effects...
PerS
So, made an update to my Cheat Sheet with the nice stuff from the 3.60 update. If anyone is interested in a quick sheet and/or a DSP-calculator for the Helix and Stomp models.
There are two different downloads – One in pdf-format, which is more of a collection of information from different sources. The other download is an MS Excel document including the information in the pdf-sheet (in the second tab) together with a DSP calculator (in the first tab). The info in the first tab is used to test ideas and to see if a configuration is allowed in a preset, including error handling (design check) and DSP information. The information in the second tab allows you to print the pdf format document in your format of choice (default is the same as the pdf-download).
Some notes
  • The DSP values comes from Ben Vesco’s site, except the ones from 3.60. Those are mine that I tested out myself using Ben’s method. I did correlate some of the DSP values on TGP and we came more or less to the same result, so it has to be true :-). Will check the values when Ben makes an update.
  • The Dark Dove Fuzz – I checked the schematic and the spec (manual) of the fuzz and it’s stated to be 130k in impedance. On TGP I got the info that the Helix model is 1M (was measured). I tried the Fuzz and have the same problem with this on as I have with the other fuzz's, and it doesn’t sound anything like the demos I’ve heard. Probably me doing something wrong (run wireless and have two buffered Boss pedal between the guitar and my Helix, so no pic-up load available…), will do some more testing.
Hope you find it useful.
//Per
  • Like 2
  • Thanks 2
