dallonjay Posted June 15, 2023 Share Posted June 15, 2023 A quick question using the send block on the HX stomp. right now my chain is guitar>distortion>amp>delay>reverb>powercab. If i put the send block in front of the distortion block, will that pass a clean signal through the send output and the rest of the chain to the powercab or should i drop the send block down into path B? Quote Link to comment Share on other sites More sharing options...
craiganderton Posted June 15, 2023 Share Posted June 15, 2023 If the block is before the distortion, you'll send a clean signal through the send output (with the level set by the Send parameter). The same clean signal at the Send block input will exit the block and proceed to the rest of the Helix chain. 1 Quote Link to comment Share on other sites More sharing options...
dallonjay Posted June 15, 2023 Author Share Posted June 15, 2023 worked like a charm. Thanks Quote Link to comment Share on other sites More sharing options...
