blitzt29 Posted June 26, 2023 Share Posted June 26, 2023 Has anyone had similar issues with what you can see in the picture? I was about to play a show last month and as I was setting up, turned on my effects. The effect blocks (assigned effects) were out of order. Bank Up & Down were not in the right order. It should be on the left two buttons (scribble strips). When I go into Stomp Mode, some effects are missing. While booting up my HX Effects the top 3 rows should read: LINE6/HX EFFECTS/BOOTING. It only reads "BOOTING" on the left upper row. I was having this problem before I updated the firmware to the latest firmware. Still having the same issues. Any help will be appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
brue58ski Posted June 26, 2023 Share Posted June 26, 2023 Did you do a full factory reset after doing the update? If you didn't, back up your whole HX Stomp; patches, IR's, Global settings, etc. and then do the full factory reset. When you restore the old patches, it should take awhile to boot up while it rebuilds them to comply with the new firmware so don't let that worry you. 1 Quote Link to comment Share on other sites More sharing options...
blitzt29 Posted June 26, 2023 Author Share Posted June 26, 2023 My HX Effects was doing this before I updated the unit to the lastest fimware. Yes, I did a full factory reset after the update. I backed everything up and I'm still having this problem. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted June 26, 2023 Share Posted June 26, 2023 I'm stumped then. Sorry I couldn't be more help. 1 Quote Link to comment Share on other sites More sharing options...
blitzt29 Posted June 26, 2023 Author Share Posted June 26, 2023 Thanks for your repsonse. The only thing that I started doing differently was I started using SNAPSHOTS. Once I started using SHAPSHOTS that's when my unit started acting weird. Quote Link to comment Share on other sites More sharing options...
