bjmort Posted July 18, 2023 Share Posted July 18, 2023 Ok so I've got a wild Idea to get the SP1-L6H working with a Helix LT. It's actually quite a simple concept, plug the expression cable in as normal and then convert the toe switch to a midi single with this and plug it into the MIDI input of the helix. The doremidi has a switch setting that will take the activation of the momentary switch on the pedal and convert it to a basic CC midi command. Now am I crazy or is this a very simple and affordable solution to get an additional toe switch? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 18, 2023 Share Posted July 18, 2023 Seems like it should work. Though, unless you already have the SP1, seems a pretty expensive solution. Quote Link to comment Share on other sites More sharing options...
bjmort Posted July 18, 2023 Author Share Posted July 18, 2023 Not really. Can get a used SP1 for $100 AUD and the MIDI converter for $60 AUD. Quote Link to comment Share on other sites More sharing options...
