Pass sound (backing track) from computer to amp via Pod Go
bkvvldmr
Hi all!
Recently purchased pod go and I'm the happiest man on the earth now because I finally got the sound I want!
Noob question about playing with backing track: I have computer connected via USB to play backing tracks + headphones connected to Pod Go via Phones input. All works great with this setup. Now I want to do the same but without headphones using my valve amp, so I connect it to Pod Go via Amp Out. The problem is I hear only guitar in Amp, backing track is not passing through Pod Go to my amp (I still hear it in headphones though). What am I missing, how can I pass sound that is coming from computer through Pod Go to my amp?
Thanks!
The USB audio input is sent directly to the POD Go audio outputs. It is not processed by the POD Go DSP. Check your Amp Out setting on the POD Go (Global Settings). Make sure it is set to Main Out, which includes the USB audio input.
The other settings taps the signal sent to the amp before the IR /Cab block In the preset, and does not include the USB audio input. If this is your current setting you may want to disable the cab/IR block in your POD Go preset.
Thanks for response!
I have Amp Out setting configured as Main Out. Tried to disable cab/ir block in preset but nothing changed. Interestingly I tried to use MAIN OUT (left/mono) instead of AMP OUT to connect to my amp - and now I'm getting backing track in my amp, but no guitar sound, so it's the opposite problem...
