pedal to snapshot
Vostorvic
I want to assign my expression pedal to different parameters per snapshot. Is that possible? I tried to copy a block and use that copy in the next snapshot but then the pedal assignments are also taken over.. Is there another way??
Thanks,
Victor
I.e. an expression predal controlling a chorus's mix parameter in Snapshot 1 and depth in Snapshot 2? -I don't think that's possible.
As workaround you can use two blocks of the same fx and assign the expression pedal to both of them and toggle on/off per snapshot .
