DomFuh Posted July 23, 2023 Share Posted July 23, 2023 Hi. I am new to the Line6 Helix and in the past have had not much experience with multieffects boards. When adjusting the volume via EXP2 pedal, when thereafter stepping off the pedal after attaining the desired volume, the volume reduces somewhat in the next milli seconds to a lower volume. Is this a settings problem or does this indicate a problem withe the hardware? It is rather frustration though. Can someone help me here? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 23, 2023 Share Posted July 23, 2023 It might actually be a foot-related issue. When taking your foot off the pedal I think it’s possible that you actually remove the heel of your foot after the toe, essentially pivoting your foot at the ball and hence placing additional pressure on the heel of the pedal as it releases. Check that out. Try consciously removing your heel first and see if the volume increases slightly. In order to take your foot off the pedal without slightly affecting the volume I think it might take a conscious effort to lift your foot straight up and ‘step’ off the pedal, bending at the knee.. Certainly my tendency is to slightly pivot off the pedal. Quote Link to comment Share on other sites More sharing options...
DomFuh Posted August 20, 2023 Author Share Posted August 20, 2023 Thank you for your help - it is indeed appreciated. I will make a consious effort when removing my foot as you have described. Looking forward to having solved this issue. Otherwise, a great product! Quote Link to comment Share on other sites More sharing options...
