HX Stomp XL won´t update, even though HX Edit says it went well
GabrielSGS
Hello,
I have just acquired a HX Stomp XL second hand that is still in firmware version 3.02.1
I have downloaded HX Edit 3.60 and tried to update the device with nno sucess.
HX Edit informs about the update, allows me to backup everything, starts the process and lands in a webpage error when it allows me to proceed. At that point the HX Stomp screen goes black but the stomps keep their glow.
HX Edit informs me then that the update was successfull and that a rebuild is in place but the HX Stomp stays the same no matter what.
If I turn it off and then on the is still stuck in the old firmware.
If I try to start hx stomp in edit mode (turn on pressing >) it doesnt power up.
Do I have a faulty unit?
Possibly not, but when seeking assistance for this sort of thing, it’s advisable to say what computer and operating system you are using. Anyhow to save lots of typing go to this thread (link below) and follow the instructions. Be aware that the instructions were compiled for v.3.5 firmware, therefore just use the latest versions of the firmware and Line 6 Updater. Follow the procedure and you should be fine.
Hope this helps/makes sense.
