gtavares Posted August 12, 2023 Share Posted August 12, 2023 Hello, hope someone can help. i am trying to use the send(L) output on my stomp XL to feed to combo amps in stereo. i use my main outs for the bands PA which is mono. I use a tip and ring adapter to split the left and right to the 2 amps. for some reason this doesn't work, it only comes out mono to the 2 amps. t test this with a ping pong delay. Does anyone know what i am doing wrong? the manual says this is possible from what i have read. I checked global settings for a mono/stereo option for the send output but didn't see one. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted August 12, 2023 Share Posted August 12, 2023 You need to use a Send L/R block instead. Send L uses tip, Send R use ring and Send R/L uses tip and ring. Quote Link to comment Share on other sites More sharing options...
gtavares Posted August 12, 2023 Author Share Posted August 12, 2023 HI Schmalle, thanks for helping. i am using a send L/R block and its set to stereo but i still getting mono to the amps. any other ideas? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted August 12, 2023 Share Posted August 12, 2023 Looks good so far. Check the Split and Mixer "blocks" for neutral panning. If that's not it: post the patch. Quote Link to comment Share on other sites More sharing options...
gtavares Posted August 12, 2023 Author Share Posted August 12, 2023 really appreciate your help. Hope you can figure this out. im stumped Possum Kingdom.hlx Quote Link to comment Share on other sites More sharing options...
Schmalle Posted August 12, 2023 Share Posted August 12, 2023 The preset uses a Simple Delay in mono. 1 Quote Link to comment Share on other sites More sharing options...
gtavares Posted August 12, 2023 Author Share Posted August 12, 2023 Geez, i thought i had that set right. thanks Schmalle. only 2nd week with the helix and 1st day trying it with an amp. do you know if there is any preference setting for having the stereo effects show by default? again, thanks for your help. Quote Link to comment Share on other sites More sharing options...
Schmalle Posted August 12, 2023 Share Posted August 12, 2023 Effects are categorized in Mono, Stereo and Legacy. The latter category is a bit of guesswork on the device. In HX Edit the stereo blocks are indicated with a symbol next to the name. Have fun! Quote Link to comment Share on other sites More sharing options...
gtavares Posted August 12, 2023 Author Share Posted August 12, 2023 your the best , thanks 1 Quote Link to comment Share on other sites More sharing options...
