StompXL: W11 complains that memory integrity does not work with driver 1.97.0.2
tcamuso
I'm getting this error message:
Quote
You are receiving this message because the Memory Integrity setting in Windows Security is preventing a driver from loading on your device. Here are a few options you can try if you want to be able to use this driver:
  • See if an updated and compatible driver is available through Windows Update or from the driver manufacturer.
  • If that doesn’t work, you can try turning off the Memory Integrity setting in Windows Security.
Warning: Turning off Memory Integrity on a Secured-core PC takes the device out of a Secured-core state. If you choose to continue using your device without addressing the driver problem, you might discover that the functionality the driver supports does not work any longer, which could have consequences ranging from negligible to severe.
So, I turned off the Memory Integrity, and the driver loads fine, but now Windows Security is complaining that my system is vulnerable as a result.
What's weird is that I have this installed on another W11 system, and I am not seeing that error message.
Anybody have any idea what I can do to fix this?
