sifusteve Posted August 29, 2023 Share Posted August 29, 2023 I managed to acquire a MK1 (I believe) Spidervalve 212 that I absolutely love. However, it appears as though the DSP chip may be failing and from what I gather may be unfixable. When it works, it sounds lovely. From what I can tell, the power amp stage looks good. I just replaced both preamp and power amp tubes with 12AX7 and a matched set of Sovtek 5881s. Biasing on the power tubes is ~32mV, and the amp has never been turned on without a speaker load. If the DSP board does fail, what options do you think I have? I would love to continue to use the power amp section of this device, but I want to do it correctly. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 30, 2023 Share Posted August 30, 2023 If it's an oxidized intermittent solder point, a Line 6 authorized service center can deal with that and do an overall check up. Tubes are still available, but other parts are not,... processor boards are all gone and no longer available. https://l6c-acdn2.line6.net/data/6/0a06434d8ea4507efaf692112/application/pdf/Spider Valve MkII Pilot's Guide ( Rev F ).pdf?_ga=2.19226620.559611353.1693237757-1854743224.1659634079 Can bypass effects and use the power amp input. MkII has MIDI In/Thru connectors, the MkI does not. Quote Link to comment Share on other sites More sharing options...
sifusteve Posted August 31, 2023 Author Share Posted August 31, 2023 psarkissian, Thank you for your reply and answers. I have taken the processor board into my own work where I have SMT rework tools and a nice bench microscope. After reflowing almost all of the solder joints, replacing some electrolytics, performing a thorough cleaning with rubbing alcohol, placing a heatsink with thermal tape on the DSP and Codec chip, the board and amplifier seem to be working. I managed to play through it for about 1 hour without incident where before it would take only 10-15 minutes for the board to act up cease to work. Thanks for the advice and direction. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted September 2, 2023 Share Posted September 2, 2023 Nice heat sinks. 1 Quote Link to comment Share on other sites More sharing options...
Golfered Posted November 4, 2025 Share Posted November 4, 2025 I have a Line 6 Spider Valve HD100 with similar problem after 15-20 minutes will shut down The processor board on this is facing down after the chassis was removed from the cabinet, making it a little more difficult getting at the DSP and CODEC chips In addition to the heat sinks, I understand maybe using a fan in this area is also helpful. Again, if all else fails, can the tube amp section still be used? Can an output from another amp be used in the amp input to carry the signal and still use the Volume at least? Thanks in advance for any suggestions. Quote Link to comment Share on other sites More sharing options...
sifusteve Posted March 31 Author Share Posted March 31 I wouldn't use another amp in the signal chain to the power amp in on the back panel. Using specifically a preamp pedal, or even a distortion pedal like a Boss Metal Zone has worked for me. Still have the presence and master volume of the power amp to play with. IMHO sounds better than the onboard DSP effects. Quote Link to comment Share on other sites More sharing options...
