paulcanning Posted November 20, 2023 Share Posted November 20, 2023 I've been using the 1 switch looper on my Pod Go and suddenly it is no longer working correctly. I can set up a loop fine and then press the assigned switch to play the loop. However, I cannot then stop the loop (should stop with 2 switch presses) or erase the loop (should erase by holding the switch down for a brief moment). It is weird, the 6 switch looper works fine. I have just updated the software but that hasn't helped. Any advice would be much appreciated. Quote Link to comment Share on other sites More sharing options...
voxman55 Posted November 21, 2023 Share Posted November 21, 2023 On 11/20/2023 at 11:08 PM, paulcanning said: I've been using the 1 switch looper on my Pod Go and suddenly it is no longer working correctly. I can set up a loop fine and then press the assigned switch to play the loop. However, I cannot then stop the loop (should stop with 2 switch presses) or erase the loop (should erase by holding the switch down for a brief moment). It is weird, the 6 switch looper works fine. I have just updated the software but that hasn't helped. Any advice would be much appreciated. When you updated did you reset back to factory as recommended by Line 6? If not, back up your patches and reset back to factory. Quote Link to comment Share on other sites More sharing options...
rs79206b Posted March 26 Share Posted March 26 Had the same issue with a new Pod Go. After a conversation with a very friendly Service guy here in Germany I pressed the switch super quick, (clickclick, not click, click), then it worked with my device. Quote Link to comment Share on other sites More sharing options...
