BaylorPRSer Posted December 2, 2023 Share Posted December 2, 2023 Hi there, My A and D buttons require a bit more pressure to turn on and off than B, C, and the FS1-FS4 buttons. Is this normal? Can it be fixed? If so, how? I see there's a buttons option in safe mode, but I don't want to go tinkering with that before I know what I'm doing. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted December 2, 2023 Share Posted December 2, 2023 On 12/2/2023 at 11:07 AM, BaylorPRSer said: My A and D buttons require a bit more pressure to turn on and off than B, C, and the FS1-FS4 buttons. Is this normal? Can it be fixed? If so, how? Internally beneath the footswitches are two separate rows of tactile switches. After disassembling them you could apply directly a good quality contact cleaner or even better isopropyl alcohol. If cleaning doesn't solve the problem then you need to replace the individual worn switches (which thing requires knowing how to solder/desolder properly) or more conveniently the entire rows of switches. Line 6 24-31-1105 - 6mm 4-pin Tactile Switch Line 6 50-02-0234 - Top and Bottom Switch PCB Assembly for HD500X _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips 1 Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted December 4, 2023 Share Posted December 4, 2023 For me, it was enough to open the unit, pop out the springs under the buttons, re-stretch the springs, put them back, re-assemble. The switch itself was just fine. 1 Quote Link to comment Share on other sites More sharing options...
