arielalmz Posted December 19, 2023 Share Posted December 19, 2023 Hi, Has anyone run into this issue? Seems that when I try to update to 2.01 version, I get this message saying "P34 unit does not identify as P34". This is what I am doing: Select "Update Now" from window prompt at POD Go Edit software Create a Backup Agree on license terms Message says download is going on and that POD Go will reboot to prepare for update Update FAILS with the specified message above. All it says is to contact customer support. I already created a ticket, but wanted to see if I could figure this out while they contact me. Does anyone has any hint to overcome this issue? Thanks, Quote Link to comment Share on other sites More sharing options...
Dan_20ysb Posted December 20, 2023 Share Posted December 20, 2023 Same here. I am trying to update from version 1.40. Any update on this error? 1 Quote Link to comment Share on other sites More sharing options...
jiml6 Posted December 20, 2023 Share Posted December 20, 2023 Try updating with Line 6 Central. Quote Link to comment Share on other sites More sharing options...
Dan_20ysb Posted December 21, 2023 Share Posted December 21, 2023 Using Line 6 Central did the job. Updating worked like a charm. Thx for the hint! Quote Link to comment Share on other sites More sharing options...
SleepyHollow Posted January 2 Share Posted January 2 I had to update the Pod updater first, then update my Pod Go and the problem disappeared. I hadn't updated in a while. Quote Link to comment Share on other sites More sharing options...
mvenet Posted January 22 Share Posted January 22 Hi, Getting same error. Followed advice on going to Line6 Central Did that and got the .hxf file download. Probably a stupid question but how do you then install that firmware file? Still seems like only option is to select update upon opening of POD Go edit which leads to same error, TX, Marc Quote Link to comment Share on other sites More sharing options...
mvenet Posted January 22 Share Posted January 22 NVM. Seems to have worked using Line 6 updater utility. I am guessing that is what previous poster meant by Line 6 central. Regards, M Quote Link to comment Share on other sites More sharing options...
