jmf394 Posted December 24, 2023 Share Posted December 24, 2023 The pedal was updated with the latest FW (Version 1.01.0) close to when the FW was released. The pedal itself was purchased close to the original release (end of March 2022). Using Ableton Live 11 for controlling things and a Focusrite Clarrett+ 8 Pre for my interface. I can communicate with the DL4, send PCs and CCs and hear things update, TAP ring turns blue, etc. When I try and store the changes to PCs, it seems to store in the "ABC" bank rather than the commanded PC. The TAP ring is still blue when I am saving. For example, I send PC11. I see the "B" button light up as anticipated. I hold "B" on the pedal to save the changes based on CC adjustments I made (TAP ring is still blue). I recall any other PC, then when I recall PC11, it is the factory setting. If I recall PC2, the setting I set up for PC11 is recalled. Global settings are mostly their default value; only ones I changed are the MIDI channel and enabling the MIDI Thru port. Is there something I am missing from the manual for saving in these PCs or have any other MIDI users with the DL4 MKII experienced anything like this? Quote Link to comment Share on other sites More sharing options...
Meco80 Posted July 26 Share Posted July 26 Same problem here. It seems a known bug as many reported it. Any fix has been found? Or scheduled by Line6 for future firmware release? Quote Link to comment Share on other sites More sharing options...
