HX Effects - How to config only wet effects for a parallel loop
joanesinu
Hello,
I have this layout. The send is for the input of the amp. Can an effects block cut the signal when bypassed? I mean, my intention is to set reverb and delay full wet. And when I activate those effects, only the wet signal will go to the parallel loop. When the blocks are bypassed, I don't want any signal thru them, cause that would create phase issues (Same guitar signal on input and parallel loop effects return).
Is any way to do that?
