Externa expression pedal not working. Helix rack
Perake
Hi!
After updating my Helix rack to the latest firmware my external expressionpedal stopped working. I use a Ernie Ball pedal as waw-wah,  connected to the Helix floorunit.
Everything else working,  all presets are ok.
Any thoughts what has
Second question, is it possible to build a patch so the expression pedal is normally  a volumepedal but change to a wah-wah by clicking a button?
1) Did you restore the Global Settings after updating the firmware? The update resets the Globals to the default values and perhaps has affected your external pedal settings.
2) Yes. Assign the same footswitch to control Bypass of both Vol and Wah FX blocks, and then Save the preset with one block active and the other bypassed. Henceforth a press of the switch toggles between the pedals. Similarly, assign the same EXP pedal to control the sweep of both FX blocks.
