Can I run at 12v?
Paddy544
Title says it all really.
I believe a lot of 9v pedals can safely run at 12v and I'm hoping that's the case here.  My power supply will be overloaded if I add the HX One to my board and introduce a lot of noise.  It does however have a separate 12v output delivering 500ma that would do the job.  If the HX One can't then I'm going to need a new power supply.
Thanks
Pat
  • 1 month later...
Don't do it. Digital pedals are much more susceptible to overpowering. There are zero resources from Line6 stating that the HX One can run safely at 12v, and you'll likely void your warranty by doing so, which you would find yourself in need of once you blew components on your pedal's power circuit.
