rustydomino Posted March 5, 2024 Share Posted March 5, 2024 hi all, is there an easy way to monitor playback from my Pod Go plugged into a Mac with monitor speakers? I know how to do this by running Logic and using the Pod Go as an input source, but it seems to me that there should be a way to do this without having to run Logic if all I want to do is just play and not worry about recording... and while I am at it, I guess I have the same question for a Windows PC. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 5, 2024 Share Posted March 5, 2024 Connect your monitors directly to the POD Go audio outputs. Quote Link to comment Share on other sites More sharing options...
rustydomino Posted March 6, 2024 Author Share Posted March 6, 2024 Sorry, I guess I was being unclear. The monitors are already plugged in to the Mac, and the goal is to not have to unplug them. I know this sounds super lazy - but in PRINCIPLE there OUGHT to be a way to play straight from Pod Go ---> USB to a Mac ---> Mac Speakers without a DAW, no? Firing up a Logic session (or any DAW) just for the purpose of practicing just seems silly, even though it works and I know how to do it. Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 6, 2024 Share Posted March 6, 2024 I chose the path of (in my case at least) better sound quality. My Helix is a better quality soundcard than the one in my PC, and my studio monitors are also superior to the internal PC speakers and to most external speakers designed for general use with a PC. My studio monitors remain connected to my Helix at all times and I have the Helix powered on when using audio from my computer, DAW or not. My PC is configured to use the Helix as its default audio device. Quote Link to comment Share on other sites More sharing options...
Krabin Posted March 25, 2024 Share Posted March 25, 2024 I've never used a mac, but in windows, there's a quick way to do this, and there might be a similar way in your mac settings. In the windows sound control panel, you can right click the pod go listed under playback devices, click properties, and there is an option to "listen to this device" and route the audio to your output of choice. However, this tends to have a ton of latency in my experience. This us likely due to the fact that this option probably doesn't take avantage of ASIO drivers for minimal latency, while any good DAW does. There are plenty of cheap or free DAWs that can easily do this. I'm pretty sure garageband supports ASIO drivers. It would be nice if your monitors had another input. If not, another possible solution: buy or make a cheap A/B switch so that you can switch between your PC and POD Go to go to your monitor input. You might be tempted to use a Y cable to have both your PC and POD Go routed to your monitor input at the same time but do NOT do this. Your PC output would also be running into the POD Go output and vice versa, and running one ouput into another can be anywhere from bad to VERY BAD. Quote Link to comment Share on other sites More sharing options...
