ralban_line6 Posted March 9, 2024 Share Posted March 9, 2024 I received my Pod EXPRESS last night and am really enjoying it so far. I've been experimenting with FS 3/4 settings to see how best to maximize Pod Express as a backup or fly-rig. Here is what I've noticed so far, curious to hear what others are trying. My global settings are as follows: Preset Select | AQUA | Load On/Off (not default) TAP Tempo | AQUA | Global (not default) Volume Jack | WHITE | FS3/FS4 (not default) ON Assign | LIGHT ORANGE | Distortion On/Off (not default) TAP Assign | RED | TAP/Tuner (default) FS3 Assign | BLUE | Modulation On/Off (not default) FS4 Assign | GREEN | Delay On/Off (not default) My thinking here is: Preset Select Load On/Off lets you move to presets that are not sequential. I don't see myself making song-specific presets, so having TAP rate per preset doesn't seem useful. I could see making 2 presets for a song and use one of those presets for a volume boost (e.g., duplicate a preset and save it with a slightly higher CH. VOL level). When in PRESETS mode (ON+TAP), ON and TAP always seem to scroll NEXT/PREVIOUS presets; regardless of FS3/FS4 settings. This being the case, I don't see a benefit to using FS3 or FS4 to be NEXT/PREVIOUS. If I were to have an expression pedal, I would just get a real volume pedal and run it in front of POD Express and not use the VOLUME pedal in the signal chain after the CAB block. Assigning DIST to ON, MOD to FS3, and DELAY to FS4 provides the most control within a Preset. (You could assign FS3 or FS4 to REVERB, but I tend to always keep a light reverb on). Observations so far: Effect bypass states seem to be global. That is, if I bypass DISTORTION and go to the NEXT preset, DISTORTION will be off even if I saved that preset with DISTORTION on. Pressing FS3 + FS4 together seems to toggle EFFECTS ON/OFF 1 Link to comment Share on other sites More sharing options...
dankrzykowski Posted June 5, 2024 Share Posted June 5, 2024 Have you noticed that if you assign individual effects to FS that you can't have an UNASSIGNED effect on? For example, I have Dist on FS1, Delay on 2, and Reverb on 3. This means I simply can't have Mod on. That's annoying. 1 Link to comment Share on other sites More sharing options...
