BocaBoy51 Posted May 9, 2024 Share Posted May 9, 2024 Hello all I would like to be able to Midi from my Boss DR770 to the Tap of my POD HD500X. Most of the reading I've have come across has the POD as the controller using Midi out to control another deivice. I would like to do the opposite, have my DR770 control the tap speed. If this is not possible would appreciate any suggestion on how I can sysnc the two devices Thanks Quote Link to comment Share on other sites More sharing options...
hurghanico Posted May 10, 2024 Share Posted May 10, 2024 As you can see in the pic above, the POD Tap Tempo will respond to midi control #64 (with any value between 64 and 127). every single midi message received by the POD will correspond to 1 Tap.. Simply connect a midi cable from your drum machine's midi out to POD's midi in, set the same midi channel on both devices, make sure your drum machine sends CC #64 to the beat _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
