Pod xT Live volume pedal issue
So everything was working just fine, idk of any changes I may have made by accident. But now my volume pedal wont cut to zero output. In the settings it's still set to 0, and when I "turn the minimum volume dial up" in the monkey, it raises the minimum output up, so its responding, but when I back off the pedal, there's still sound coming thru even all the way down. So it does lower the volume, but not to zero. Any ideas?
Perhaps calibrating your pedal will help:
Q: How do I calibrate the pedal on my PODxt Live?
A:
1. Make sure there is nothing connected to your PODxt live aside from the power cable.
2. Power up the PODxt Live while holding down the Bank Up pedal
3. Press the Amp pedal (this will reset the current settings)
4. Move the pedal all the way to the heel back position, then all the way forward until the toe switch clicks. You will want to stand up and shift all of your weight to the toe position until you see the WAH light turn on.
5. Wait 10 seconds, then power the PODxt Live off and back on again.
6. Your pedal is now calibrated.
