jon_bondy Posted May 25 Share Posted May 25 I am using a 12-string sound on a Variax, where some strings are doubled up 12 half tones. When using the Variax guitar, I can select a 12-string acoustic guitar model using the model selector knob, and then use the tuning selector knob to alter the pitch (perhaps to bump everything up by 2 half tones, to simulate use of a capo). At that point, the doubled tones are essentially 14 half tones above where the base tones started. When using the Helix with HX Edit, it seems that I can only specify a tone for the base and a tone for the 12-string, and the latter is limited to 12 half tones above the base. Thus, I cannot simulate both a 12-string guitar and a capo pitch shift of 2 half tones. I cannot find a way to select a position on the tuning knob, even though I can select a position on the model knob. For "Tuning (Preset)" I cannot select a tuning as defined by the tuning knob on the Variax. What am I missing? Is it true that HX Edit cannot control the Variax with the same flexibility as I can when using the Variax manually? Thanks. Jon Quote Link to comment Share on other sites More sharing options...
jon_bondy Posted May 25 Author Share Posted May 25 Never mind. I figured out a way to get it to work. Quote Link to comment Share on other sites More sharing options...
