u0088782 Posted May 30 Share Posted May 30 New HX Stomp owner. I'm trying to build a preset with 3 guitars and 1 keyboard always connected, then ABC the guitars as follows: Path A Main L - Guitar 1 Main R - Guitar 2 Return L - Guitar 3 Output Main L/R Path B Return R - Keyboard Output Send L/R I've gotten everything working except I can't prevent Return L (Path A) from outputing to Path B. It doesn't matter whether I choose Send L, Send R, or Send L/R at the end of Path B. The culprit seems to be Return R at the start of Path B. Despite supposedly only being the R channel, it adds Return L to the mix on Path B - deleting it removes the unwanted signal. It's weird because Return L on Path A works exactly as intended. Perhaps I'm just completely misunderstanding how routing / signal paths work... Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 31 Share Posted May 31 Make sure to set Global Settings -> Ins/Outs -> Return Type to Return. 1 Quote Link to comment Share on other sites More sharing options...
u0088782 Posted May 31 Author Share Posted May 31 Sadly, that wasn't it. Any other suggestions? Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 31 Share Posted May 31 I see you use Mix 50% on Path B's Return R block. That should be 100% unless the Split block is set to Split A/B with RouteTo set to A100. Otherwise the guitars 1 and 2 bleed through. Also you don't need to use the Send block: select the Mixer block, press Action and select Path B. If that doesn't help: post the patch. 1 Quote Link to comment Share on other sites More sharing options...
u0088782 Posted May 31 Author Share Posted May 31 Yeah, I'm using Split A/B Route to A100. I started with a Mixer block, but that didn't work either. Preset attached. Thanks again! I really appreciate it. TEST.hlx Quote Link to comment Share on other sites More sharing options...
Schmalle Posted May 31 Share Posted May 31 I can confirm that the patch does exactly what you described IF no cable is connected to Return R. HX is auto-merging channels when you use the left input or left return only it is internally distributed to the right channel. In other words: by unplugging from the right return the Return R block effectively becomes a Return L block. 1 Quote Link to comment Share on other sites More sharing options...
u0088782 Posted May 31 Author Share Posted May 31 Wow! That was the problem. I was swapping one cable back and forth! It was working all along. Now I know. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
