midI AND LINE6
alexdrumming
I would like to connect everything via midi: the SL88 studio to the line6 Hx effect to use the full potential of the effects and everything then connected to the boss 505 loop station. Drivers of various devices already installed the PC sees them. If I use the Sl88 studio with VST and connect it to line6 the latter only works as a pad to change the vst effects and not always. However, I would like all the necessary very detailed information for all the articles indicated, midi, midi through (currently placed on line6) I think I have put everything on midi channel 1. I have a Yamaha mg10xu mixer. I also have a DI art tube if I'm not mistaken connected to line6 but I use it with a microphone with line6 effects. So if you need other cables and if I necessarily have to use it in this case kindly write to me also what you need to buy, cables etc. And how to connect them. If more convenient, send a drawing. I kindly ask for information on how to connect the SL88 with its software and if I don't have to use VSTs but open a DAW (like Studio One). Thank you, I'll wait and thank you in advance. I would also like to put a passive DI out of the unbalanced output of the PC, see article 10899, also write me cables for the latter. Thanks I think I've said it all. Good day
  • 1 month later...
