rafaelpereiraa1 Posted July 24, 2024 Share Posted July 24, 2024 Hello! I have been facing problems regarding sensitivity with my Dunlop DVP4 Mini expression pedal and my HX Stomp XL. In the video below, I demonstrated how practically 40% of the pedal's expression does not work. I noticed that with the volume block, the sensitivity is better than with Wah blocks. With the volume block, I can cover about 90% of the pedal's sensitivity. Note: Inside the DVP4 Mini the key is EXP. Quote Link to comment Share on other sites More sharing options...
theElevators Posted July 24, 2024 Share Posted July 24, 2024 Try changing the polarity of the expression pedal on the HX stomp. I think there are several settings (not in front of my Helix at the moment). If you go to global settings/expression pedal 2; you can cycle through various options. If that doesn't help, there's this thing, same pedal as you've got: Quote Link to comment Share on other sites More sharing options...
