cdhcdhcdh Posted July 31, 2024 Share Posted July 31, 2024 Hello! Just bought a HX One and placed it as the first pedal in my FX loop with a mono send from my Boss IR-2 (it only has a mono send). I then want to go stereo out into my reverbs and delays, then back into the stereo return of the IR-2. But when I try to go mono in, stereo out, I only get sound out of one headphone ear. Pedal works fine when I run mono in, mono out, but then I lose the stereo panning and delays I bought this thing for. Reordering the board and putting a delay before the HX One would mean buying another cable, which is annoying, and I can't use pitch effects and my delay at the same time. Any help would be amazing! Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 31, 2024 Share Posted July 31, 2024 See pg27 of the manual re:: I/O Config parameter. Here’s the description: Choose “Stereo” for discrete left & right stereo signal paths when connecting to both IN and both OUT jacks. Note that if no cable is connected to the OUT - RIGHT jack, your HX One output is folded to mono. You may need to split the mono output from your Boss IR2 into a dual mono feed to both HX One inputs. Quote Link to comment Share on other sites More sharing options...
