Will the Mission Engineering SP1-L6H Expression Pedal work with the HX One?
DdC441
Hey all! I have a Mission Engineering SP1-L6H expression pedal w/built-in switch I used with an HX Stomp XL I had. Does anyone know if the HX One will respond to both the expression pedal and built-in switch like the Stomp? I have the 2-TS to 1-TRS cable. I'm thinking if it can respond to a 2-button expansion pedal, it could respond to one expression pedal and one switch. Hope that makes sense.
Any insight would be appreciated!
Thanks!
Nevermind! I found the following in the PDF manual I downloaded. I'm posting it here for future questioners.
Quote
The HX One EXP PEDAL jack is a TRS type jack, into which you can connect a single expression pedal using a TS cable, or a dual-footswitch using a TRS cable. It is also possible to connect an expression pedal with a TS cable and a footswitch with a TS simultaneously, provided you connect them into a dual TS-to-TRS splitter (or “Y” adapter)
