Helix in Fryette Powerstation Loop and Friedman Plex
spinalmuppet
Hi everyone, I'm hoping someone can help me set up my rig. I've been using the Helix floor for a while and love it, but sometimes I just love a real amp. Ive got a Friedman Plex which sounds amazing but has no fx loop.
So I'm using a Fryette Powerstation to use effects in its loop. Lots of videos on YouTube with people doing the same.
Whatever I do the volume is really low or nothing at all?
I'm using the Powerstation as a load into a 2x12 and want to use at least the time based effects but would love to be able to use a boost as well.
Can someone tell me how to connect this up for best results, 4CM or other please?
I'm obviously missing something. Thanks.
Once you leave the amp and go into the Fryette, the signal level is astronomical compared to the amp input and the levels that the Helix operates at. I am not familiar with how the Fryette loop operates but, to be compatible with a modeller, it would have to drop the signal down to instrument/line level from its Send, and then amplify it back up when it gets it back through its Return. It may have this sort of feature, but I rather doubt it. If it does not have this feature, you will lose the signal boost from the amp's power stage that is designed to drive a speaker, and you will be back down to Line level which will certainly not drive a speaker.
