M13 - Dual Instrument Input / Toggle
gswipe
Hello,
I have an M13 which I use to run some effects for my violin & mandolin. To switch between instruments, I use a separate ABY switcher pedal, which is not bad. But I would like to know, can I use the M13 for this function? Where both instruments could be plugged in and toggled between? My initial thought was to use the L/R on the input and pan one way or the other. Is that doable? Is there a better way?
Thank you very much!
