GB_pro Posted October 22 Share Posted October 22 Hi, I was wondering if it is possible to split the B-path on the hx stomp, in order to use 2 separate signal splits (for different effects in the signal chain). When I try to do so, the B path automatically merges to one. I couldn't find a solution so far. Best regards and thanks in advance! Quote Link to comment Share on other sites More sharing options...
Schmalle Posted October 22 Share Posted October 22 You won't find a solution because you can only split the signal once in a patch in HX Stomp. Quote Link to comment Share on other sites More sharing options...
GB_pro Posted October 22 Author Share Posted October 22 Oh ok, thanks. That's the explanation then, unfortunately. Quote Link to comment Share on other sites More sharing options...
