demon_cleaver Posted November 9, 2024 Share Posted November 9, 2024 Has anyone used the Pedal Power 2+ to power the HX One? Using the current doubler Y cable on outputs 5, 6 with dip switches set away from normal the manual says it’ll provide 12V, 500mA. Is that too much voltage for the digital pedal? Does anyone know if setting the dip switches to normal the output will be 9V, 500mA with the Y cable or do the switches need to be set away from normal for it to double the current? Thanks! Quote Link to comment Share on other sites More sharing options...
