strickton
Cant Update The Firmware On My Spider Iv 150
Ok. By mistake i deleted the post so ill try again :) Ill still get the Cod 80009000 unknown midi error. Need help!
Ok, again:  are you using Spider Monkey?  First update the FBV pedal's firmware, then connect the amp to the FBV.  You should not be getting a MIDI error if you are updating the firmware.
Thanks for the help. Done the update like you said but the midi error code: 80009000 is still there.
What do you mean by 'Done the update"?  Were you able to update the FBV firmware, or did Monkey tell you that you have the most current version of hte software already?  When do you get the error code?  Sorry, hard to help you without details on what you are doing.
Im using Spider Monkey.  First i updated the FBV pedal's firmware, then i connect the FVB pedal to the amplifier, turn it on and start Spider Monkey. Spider Monkey finds the amplifier and i just klick the update firmware button. In the middle of the update the  cod 80009000 midi error comes.
I think you should call Line 6 tech support.  The US support team can be reached at 818-575-3600 (option 2), Mon-Fri 8am - 5 pm PST. Our busiest hours are from 11am to 2 pm.
