kontrol3 Posted November 29, 2024 Share Posted November 29, 2024 hi, i use an exp pedal to control Mix, which becomes Loop playback volume, in Classic Looper mode. Additionally, in Classic Looper mode, the other 4 knobs Time - Repeats - Tweek - Tweaze become the Class Looper built-in delay controls. Assuming anyone reading here understands that to assign, eg, the exp ped heel-to-toe to Mix for Classic Looper VOLUME PLAYBACK as per the manual, there is no button to hold down, like as assign values button, you simply turn a knob(s) with exp pedal at one position, then you move the pedal to another position and turn the knob again; that sets/assigns kob(s) parameters the exp pedal. Done. Ok, so Exp pedal is assigned, as per manual, to control (Classic) Loop playback volume (Mix knob). Problem: after the above assignment f you turn the “built-in” delay knobs — the exp pedal gets assigned to those, too. So, when you ride that exp ped loop playback volume you hear, eg, time running up and down… and whatever else of those 4 (classic looper built-in delay) knobs. My only solution has been to not use the Classic Looper built-in delay. Or, turn them all to zero and try to get the exp ped NOT to do that. Can someone test this or tell what I am doing wrong. That “built-in” delay is one the reasons I bought it. Thank you Quote Link to comment Share on other sites More sharing options...
