xpodx Posted December 17, 2024 Share Posted December 17, 2024 Trying to use Poly Sustain on the HX One like I would on the Helix Devices - where you can set it to Footswitch to Momentary to capture whatever notes you are playing at the moment. Going through manuals and videos and I can't seem to find a way to edit the footswitch bypass settings like you could on other Helix devices. Hoping it's possible. 1 Quote Link to comment Share on other sites More sharing options...
Schmalle Posted December 17, 2024 Share Posted December 17, 2024 I don't see momentary bypass either. It seems only possible with an external MIDI switcher using CC#1 or CC#4. But the Poly Pitch captures the stuff that is played the moment it is engaged. Doesn't this work with the On footswitch? [Can't test - don't have an HX One] 1 Quote Link to comment Share on other sites More sharing options...
xpodx Posted December 18, 2024 Author Share Posted December 18, 2024 Yes it works but it's a lot more clumsy than momentary latching if your making chord changes (as you would on most freeze pedals). Involves double clicking instead of one, so you need to time it right; and the music abruptly stops between switches (though maybe that's just something in the settings I can fix). 1 Quote Link to comment Share on other sites More sharing options...
Joe_Fitzler Posted January 24, 2025 Share Posted January 24, 2025 @xpodx i have the same problem... would love to use my freeze as momentary, similar to a pianist's sustain pedal. Hopefully, Line 6 will add this feature?! Quote Link to comment Share on other sites More sharing options...
