G10TII unfunctional after update
Hi! Greetings. A few days ago (last week), I was updating my Line 6 POD GO Wireles through POD Go Edit to the newest version available. It was updated to the version (2.00.0) in that moment. I have the transmitter RELAY G10TII. Right after the update was completed my transmitter's light turned faint red (very low bright) and since then it's not being recognized by my POD GO Wireless. I cant's play nothing! It's unusable. My POD Go Wireless does charge my RELAY G10TII. When I plug it in, it shows it's charging, but the faint red light doesn't change, it always stays that way all the time since then. When I play with it, the unit does not recognize it. Doesn't work! ---- Here are the steps I tried: 1- I tried factory reset on my POD GO Wireless by pressing buttons C and D and turning on the unit. The factory reset was sucessful, but the transmitter didn't work. 2- I tried updating my unit through Line 6 Updater to the newest version. Update complete! Transmitter didn't work. 3- I tried updating my unit through Line 6 Updater to all versions available (one by one) in order to see if the problem with it gets resolved. All updates were sucessfull. Transmitter didn't work. 4- I tried unpluggig and plugging the transmitter back in several times to verify if it gets recognized by the unit and works. Transmitter didn't work. I am really lost and feel really sad! I just have 3 weeks with my unit and this problem came for just updating my unit (as recomended). If I knew this issue would occur I hadn't updated my unit and would have continued with it the way it was, eventhough stayed with no updates. I Don't know what else to do! Tried looking for all information on Line 6 troubleshoting pages, but all those steps didn't work for my transmitter. PLEASE HELP!
CURRENT DETAILS ABOUT MY PRODUCTS.pdf
  • 3 weeks later...
DId you get a resolution for this? Exact same issue for me after updating the Pod Go to 2.50.0. Prompted to update the G10II, I went through the process, said it was done, faint red/pink light and its cooked.
I have raised a ticket... so far have not gotten very far aside from flash the POD GO firmware again, which I have done in several different ways and it works, but the wireless is still not working, just a pink light mocking me.
Same exact issue with mine . this is the second time it happens. the first time i had to send my transmitter back and they sent me a new one, but like i said this just happened again. im gonna submit a ticket to see what they say...
Je vois que le problème est rependu !
J'ai exactement le même problème. Je suppose que la mise à jour est à l'origine de ce problème.
J'espère juste que nous ne sommes pas que trois à le rencontrer. Et que Line 6 s'en préoccupe.
Toujours pas de solution ?
