AaronKerr1979 Posted 6 hours ago Share Posted 6 hours ago I have updated, the whole process went smoothly. Ive tried 5 or 6 times holding down C and D while powering on, and it just boots up as normal. Any ideas? I was a beta tester for this update Quote Link to comment Share on other sites More sharing options...
silverhead Posted 5 hours ago Share Posted 5 hours ago What do you mean by 'boots up as normal'? There's no obvious difference during boot up but you will notice after the factory reset that the User folder of presets is empty (i.e. contains only New Preset). If it was empty before you reset then there will be no difference except that there may be different factory presets which you might not notice. There will also be a change in Global Settings which again you might not notice if you had never customized any of the globals. Quote Link to comment Share on other sites More sharing options...
